Failed to upgrade v5.0rc11 on RB600A + RB616 to v5.0 and v5.1.
Netinstall v5.0 and v5.1 not working with this RB600A + RB616.
When I tried to reinstall v5.0 or v5.1 with netinstall-5.0rc11 even simple configuration with bridges crash the system:
MikroTik 5.1
new-router Login: skb_over_panic: text:89f56a14 len:160 put:160 head:86d43200 data:86d43240 tail:0x86d432e0 end:0x86d43240 dev:
Oops: Exception in kernel mode, sig: 5 [#1]
RB333/RB600
last sysfs file: /sys/bus/spi/uevent
NIP: 801ca214 LR: 801ca214 CTR: 8016da60
REGS: 87ffde70 TRAP: 0700 Tainted: P (2.6.35)
MSR: 00029032 <EE,ME,CE,IR,DR> CR: 24000024 XER: 20000000
TASK = 803003c0[0] ‘swapper’ THREAD: 8031a000
GPR00: 801ca214 87ffdf20 803003c0 0000007a 00003895 ffffffff 8016e5a0 00000000
GPR08: 80324dfc 80300000 00003820 0000000a 44000082 10019a74 89f5afbc 80300000
GPR16: 86e9c300 86e9c30c 00000040 86e9c4c0 80300000 00000000 00000000 000003ff
GPR24: 00000001 0000003f 86f588c0 86f8c000 86e9c000 86e9c300 0000012c 86e9c30c
NIP [801ca214] skb_put+0x78/0x88
LR [801ca214] skb_put+0x78/0x88
Call Trace:
[87ffdf20] [801ca214] skb_put+0x78/0x88 (unreliable)
[87ffdf30] [89f56a14] 0x89f56a14
[87ffdf80] [801d30c8] net_rx_action+0xbc/0x174
[87ffdfb0] [800396bc] __do_softirq+0xc0/0x144
[87ffdff0] [80010db4] call_do_softirq+0x14/0x24
[8031be70] [800059ac] do_softirq+0x78/0x84
[8031be90] [80039808] irq_exit+0x60/0x70
[8031bea0] [8000585c] do_IRQ+0xd0/0x13c
[8031bed0] [80011a84] ret_from_except+0x0/0x14
— Exception: 501 at cpu_idle+0x8c/0xe4
LR = cpu_idle+0x8c/0xe4
[8031bf90] [8000948c] cpu_idle+0xe0/0xe4 (unreliable)
[8031bfb0] [80003e2c] rest_init+0x64/0x78
[8031bfc0] [802dd744] start_kernel+0x2bc/0x2d0
[8031bff0] [00003438] 0x3438
Instruction dump:
7c0803a6 4e800020 80030014 80e300b8 2f800000 810300bc 419e001c 7c8802a6
3c60802c 90010008 38639924 48080d2d <0fe00000> 3d60802c 380b9068 4bffffe0
Kernel panic - not syncing: Fatal exception in interrupt
panicSaver: dumping panic to flash
flash: erase 1c
flash: prg 1c
flash: prg err 0
Rebooting in 1 seconds..
So the question is RB600A not supported now or it’s just a bug?
