My RB600A have very strange problem.
After boot serial console is frozen
( from bios - its working ok)
RouterBOOT booter 2.19
RouterBoard 600A
CPU frequency: 400 MHz
Memory size: 128 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Starting...
Starting services...
and that all, no more input.
I (lucky) managed to set ip via netboot and log in ssh to the board
[admin@MikroTik] /system routerboard> print
routerboard: yes
model: "600A"
serial-number: "189801EFECAD"
current-firmware: "2.19"
upgrade-firmware: "2.19"
[admin@MikroTik] /system> console print
Flags: X - disabled, U - used, F - free
PORT TERM
0 F serial0 vt102
Console in bios is working ok, but afre boot hang:
your choice: s - serial console
Select baud rate for serial console:
- 1 - 115200
2 - 57600
your choice: i - board info
Board Info:
Board type: 600A
Serial number: 189801EFECAD
Firmware version: 2.19
Memory size: 128 MB
eth1 MAC address: 00:0C:42:32:B4:1A
eth2 MAC address: 00:0C:42:32:B4:1B
eth3 MAC address: 00:0C:42:32:B4:1C
Can I fix console access ?
Best regards,
Artur
