RB600A, with 4 wireless cards
Am just setting up a new RB600 with 4 cards installed, but the interface list says Wlan1, wlan2, wlan2, wlan3. This will be very confusing for setting up. How do you do a factory reset? If this would help.
All cards are RB52H. They are all able to be enabled.
Any help please?
edit
Also, how does one identify which slot starts slot0 etc. There doesn’t seem to be any markings on the board. The 433 boards seemed logical, as did the 133 boards.
If you reset, the cards will still be named the same.
I go by the mac address itself, then name the card whatever it is, AP, p2p shot, etc.
just rename them :confused:
OK thanks Inox, didn’t realise that was so simple
