RB711-2Hn and omni antennas
i need to know RB711-2Hn working if i add to it any omni antennas or must sector antennas ??
or some one advice me about RB have build in wireless card and working with any omni antennas to make it Station and Supported frequency: 2Ghz band: 2192-2539Mhz
your RB711-2Hn have level 3 …so you can not use it as acccess point unless you update it to level 4
use RB912UAG-2HPnD and you connect it with omini antenna ( single chain ) or any 2.4 sector antenna ( dual chain )
see http://routerboard.com/RB912UAG-2HPnD
thanks laithmikrotik then level 3 can’t use station option or Ap must be level 4 ??
need to know another thing i see 2x MMCX connectors can make one antenna Ap and another Client ( station ) ??
absolutely no…one connector for chain 0 the other for chain 1…
Here is the list of all levels:
http://wiki.mikrotik.com/wiki/Manual:License
For an access point you need Level 4 or higher.
Haik
