RB711-5Hn problems
I have problem with my RB711-5Hn , at log I see:
“00:0C:42:F0:7E:21 failed to join recently
no network that satisfies connect-list, by default choose with strongest signal
failed to select network”
Can enyone help me with that ?
connect-list on “CPE side” isn’t the correct MAC of the “AP side”
But there on AP side I have default-authenticate=yes
access list is to give access to this AP, or.. not necessary if you have default autentication=yes.. like you have
BUT
if you have a MAC address in your connect list (connect list of the CPE), you are saying to your “CPE” that only is able to connect to this MAC. Then, if you want to connect to another MAC, add this MAC to the connect list or delete all MACs.
Leave all disabled in your connect list (CPE side) or add the MAC address of your AP.
i have the same problem, but the Connect List is empty.
What can i do?
The Failure-Log:
20:42:06 wireless,info 00:0C:42:FE:26:6F@wlan1-gateway: lost connection, not polle
d for too long
20:42:10 wireless,debug wlan1-gateway: must select network
20:42:10 wireless,debug 00:0C:42:39:9D:55: on 5320 AP: yes SSID WLAN-1 caps 0
x421 rates 0xff00 basic 0x100 MT: yes
20:42:10 wireless,debug 7C:4F:B5:D2:E2:82: on 5240 AP: yes SSID WLAN-2 caps 0
x11 rates 0xff00 basic 0x1500 MT: no
20:42:10 wireless,debug wlan1-gateway: no network that satisfies connect-list,  by
20:42:10 wireless,debug wlan1-gateway: failed to select network
20:42:13 wireless,debug wlan1-gateway: must select network
20:42:13 wireless,debug 00:0C:42:39:9D:55: on 5320 AP: yes SSID WLAN-1 caps 0
20:42:13 wireless,debug 7C:4F:B5:D2:E2:82: on 5240 AP: yes SSID WLAN-2 caps 0
20:42:13 wireless,debug wlan1-gateway: no network that satisfies connect-list,  by
20:42:13 wireless,debug wlan1-gateway: failed to select network
20:42:16 wireless,debug wlan1-gateway: must select network
20:42:16 wireless,debug 00:0C:42:39:9D:55: on 5320 AP: yes SSID WLAN-1 caps 0
20:42:16 wireless,debug 7C:4F:B5:D2:E2:82: on 5240 AP: yes SSID WLAN-2 caps 0
20:42:16 wireless,debug wlan1-gateway: no network that satisfies connect-list,  by
20:42:16 wireless,debug wlan1-gateway: failed to select network
20:42:19 wireless,debug wlan1-gateway: must select network
20:42:19 wireless,debug 00:0C:42:39:9D:55: on 5320 AP: yes SSID WLAN-1 caps 0
20:42:19 wireless,debug 7C:4F:B5:D2:E2:82: on 5240 AP: yes SSID WLAN-2 caps 0
20:42:19 wireless,debug 00:0C:42:FE:26:6F: on 5180 AP: yes SSID WLAN-3 caps 0x421 r
20:42:19 wireless,debug wlan1-gateway: no network that satisfies connect-list,  by
20:42:19 wireless,info 00:0C:42:FE:26:6F@wlan1-gateway established connection on 5
180, SSID WLAN-3
The Problem came 5 to 15 over the day. The Link is 5 KM with -72 dbm with 90% CCQ. Any Ideas?
Where can help?
I have increase the hw-retries to 15 but the same problem.
I have set the Signal in the Connect-List but the same problem.
The Log-Failure came with NV2 too.
Anyone Ideas?
