As per MikroTik’s policy you can not upgrade License level.
There are no license level upgrades, if you wish to use a different license Level, please purchase the appropriate level. Be very careful when purchasing for the first time, choose the correct option.
Yes, by updating License i meant buying License level 4.
I just want to make sure buying level 4 will work for my situation as i dont want tot make another fast idiot decision.
Yes, for AP at least Level 4 License require there also written “There are no license level upgrades, if you wish to use a different license Level, please purchase the appropriate level. Be very careful when purchasing for the first time, choose the correct option.”
That means it is not possible to upgrade Level 3 to Level 4.
Yes, i saw that bit of license needed a little too late.
I bought this unit in a flash, not doing enough research.
Anyway, i have removed the license from the unit so i’m at demo license.
I now have it configured as an access point and it seems to be doing fine. So i will buy the level 4 license and add it to the rb711.
