RB711 Netinstall
I had used Netinstall many times and had procedure - serial lead with “putty” and change boot order on device boot up - then with netinstall program have my laptop on a static ip address in the same range of netinstall boot server - connection was made and files transfered,
http://wiki.mikrotik.com/wiki/Netinstall
Now with a RB711 followed instructions http://routerboard.com/pdf/341/rb711A-5Hn-qg.pdf
Buttons and Jumpers
● RouterOS reset jumper hole (RESET, marked with a black circle in the diagram above, below S301) – resets
RouterOS software to defaults. Must short circuit the metallic sides of the hole (with a screwdriver, for example) and
boot the device. Hold screwdriver in place until RouterOS configuration is cleared.
● S301 – Holding this button during boot time will make RB711 look for Netinstall servers. Release the button after
the LED light goes out.
Held S301 at boot up and waited for a led to go off (which was led1) released button, had set netinstall program boot client enabled with ip address 192.168.88.1 - (laptop to ip address 192.168.88.2 and firewall disabled)waited and waited but no nstream came up in netinstall program? Do i need to change like before with serial connection the boot order of the RB711 and if yes how is this done?
