RB711 with Symbol devices loosing signal, Help!
Hey guys!!
I have an installation that I configured 3 RB711 (2GHz) in a showroom with a main RB711 in AP Bridge with WDS enabled and connected to 2 other RB711 in AP bridge mode as well.
All laptops connect perfectly as well as iPads, etc in the network. The problem comes with the symbol PDAs/barcode scanners that need to connect to the network to be able to take scans throughout the network.
I tried all kinds of setups of WDS and the PDAs get connection for a few minutes, then they drop the connection and never connect again or take a long time to connect when moving around the showroom.
What can I do to get those PDAs working? Is there something that I need to enable to have the Symbol devices connected all the time without disconnecting when roaming through the 3 access points?
I am really running out of ideas.
Thanks much in advance guys!
Teo
