RB711ga+19dbi panel antenna p2p link
On distance of 10km about, p2p, i get signal -80/-82 with nv2 protocol
What bandwidth maximum i can get in that pipe? two rb711ga(onboard wifi) + 19dbi panel antenas
los is clear (not buildings, not trees)
and any sugestion about hardware for 10km link p2p (bandwidth 20/30mbps) ? two sxts for example or not?
I THINK WITH WHAT U HV MENTIONED U CAN SEE THRU 4-5 MBPS
Mahnet, not understand …
u have asked what is the maximum bandwidth u can send in that link. u can increase ur antenna power and use channel width 20/40 MHz to see more bandwidth in ur pipe.
ah, ok i will try that
