Hi every one,
I want to order the “RB711UA-2HnD”
and I wish to know if I can use it for a Normal Omnidirectionnal Antena whit a single
Can some one plz Help me?
of course you can!
many thz ![]()
Hi normis,
How to select the MMCX port where I am to use the Omni Antenna?
In single chain mode, always use chain 0. Chain 1 is only for dual antennas.
You have this options in wireless interface form, under HT tab.
Anybody suggest me the best setup.
im already having mimo antenna, i want high coverage and throughput
suggest me best setup for PTMP AP mode.
711 UA 2HND - 64 MB, 400 mhz
411 AH with R52 HN - 64MB, 680mhz
433AH with R52 HN - 128 MB ,680 MHZ.
