Hi all!
It is possible to use two chains of RB711UA-2HnD (AP purpouse) with 2 antennas, where one omni directional antenna is lolcated outside the house (coverage area around) and second omni directional antenna is inside (covering living-room)?
Kind regards
yes, that is possible configuration to use since you are using 2 antennas anyway.
Have you got any information how I can it configure? It is default settings for RB with mimo ?
