I've tried to setup vlan on RB750 and dlink switch DES-1100-16. So I've created vlan 2 on switch and router. On router vlan interface is ether5, on switch port 2 is untagged and port 16 is tagged and connected to mikrotik on ether 5. I've created secondary dhcp on vlan interface. When I connect computer to port 2 on dlink I've got ip address from mikrotik, but can't ping gateway nor internet. If I connect to mikrotik port 2-4 everything works fine. Pls advice. Here is my config:
feb/09/2016 17:27:28 by RouterOS 6.34.1
software id = 2EUI-13ZG
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=
ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=
ether4-slave-local
/interface vlan
add interface=ether5 name=vlan2 vlan-id=2
add name=default-dhcp ranges=192.168.88.100-192.168.88.250
add name=dhcp_pool1 ranges=192.168.0.100-192.168.0.200
add address-pool=default-dhcp disabled=no interface=ether2-master-local
lease-time=1d name=default
add address-pool=dhcp_pool1 disabled=no interface=vlan2 lease-time=3d name=
dhcp1
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
add address=192.168.88.1/24 comment="default configuration" interface=
ether2-master-local network=192.168.88.0
add address=x.x.x.x/30 interface=ether1-gateway network=x.x.x.x
add address=192.168.0.1 interface=vlan2 network=192.168.0.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=
ether1-gateway
add address=192.168.0.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=
192.168.0.1
add address=192.168.88.0/24 comment="default configuration" dns-server=
8.8.8.8,8.8.4.4 gateway=192.168.88.1
add action=masquerade chain=srcnat comment="default configuration"
out-interface=ether1-gateway to-addresses=0.0.0.0
add distance=1 gateway=x.x.x.x
