RB750: Bandwidth management with NAT problem.
I need to share bandwidth to all clients on a RB750 with a DSL PPPoE connection as the WAN port and ether2-local-master as LAN port. Everything is working great except bandwidth sharing. The DSL connection is 3Mbps. I want to allow users to get up to 3Mbps if available and to distribute bandwidth equally when needed. The RB750 is setup with DHCP server and NAT Masquerade. Just your typical router setup, but with bandwidth sharing. Why is the bandwidth sharing not working?
Here is the configuration:
/interface pppoe-client
add ac-name=“” add-default-route=yes allow=pap,chap,mschap2 comment=“” dial-on-demand=no disabled=no interface=ether1-gateway max-mru=1480 max-mtu=
1480 mrru=disabled name=pppoe-out1 password=xxxx profile=default service-name=“” use-peer-dns=yes user=user@isp.com
add name=default-dhcp ranges=192.168.2.10-192.168.2.50
add name=pptp ranges=192.168.2.230-192.168.2.240
add add-arp=yes address-pool=default-dhcp authoritative=after-2sec-delay bootp-support=static disabled=no interface=bridge1 lease-time=1d name=
default
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.2.0/24 comment=“default configuration” dns-server=192.168.2.1 gateway=192.168.2.1
add action=masquerade chain=srcnat comment=“default configuration” disabled=no out-interface=pppoe-out1
/ip firewall mangle add chain=forward src-address=192.168.2.0/24
action=mark-connection new-connection-mark=users-con
/ip firewall mangle add connection-mark=users-con action=mark-packet
new-packet-mark=users chain=forward
/queue type add kind=pcq name=pcq-download pcq-classifier=dst-address pcq-limit=50 pcq-rate=0 pcq-total-limit=2000
/queue type add kind=pcq name=pcq-upload pcq-classifier=src-address pcq-limit=50 pcq-rate=0 pcq-total-limit=2000
/queue tree add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=512k max-limit=3M name=Download packet-mark=“” parent=ether2-local-master
priority=8 queue=default
/queue tree add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=queue2 packet-mark=users parent=Download priority=8 queue=
pcq-download
/queue tree add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=128k max-limit=512k name=Upload packet-mark=“” parent=pppoe-out1 priority=8
queue=default
/queue tree add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=queue4 packet-mark=users parent=Upload priority=8 queue=
pcq-upload
/queue tree add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=queue5 packet-mark=users parent=ether2-local-master
priority=8 queue=pcq-download
/queue tree add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=queue6 packet-mark=users parent=pppoe-out1 priority=8
queue=pcq-upload
what exactly is not working? do you see the traffic in your queues?
Hosts on the LAN are exceeding the 512kbps download rate set on the MT. Once I have verified it is working with the 512kbps, I would like to set the rate-limit=0 and Max-limit=3mbps. I am not sure of the upload yet, but the download is not working.
On the Queue Tree tab I see the average rate fluctuate in the Download and Upload queues. I am using torch on the ether2-local-master interface. Torch will show a single LAN IP using 1+Mbps for Tx Rate, which should be limited to 512kbps by the Download Queue.
don’t double post, continue in the other topic: http://forum.mikrotik.com/t/rb750-bandwidth-management-with-nat-problem/32030/1
