I intend to buy RB750 for start, to get familiar on routerboards. And my first question is, if this model or. routerOS supports PPPoE server, or only PPPoE client.
I would like to do a small network, on wich every one connected on this network, will have to connect to internet using PPPoE protocol.
RouterOS functionality is determined by license level. When you purchase an RB750, it comes with a specific license level, and you can upgrade it to higher license levels.
correction, it supports both PPPoE server and client. If you want a bigger server, you will need to buy a Level5 or 6 license for it additionally to the router’s cost!
Similar to what I did. I’m not working 100% yet, but getting there. Though I’m posting this over PPPoE on my bench test RB450G pppoe server, authenticating to a RB1000U w/ user manager.
Log in with serial and run the setup, that is the easy way to get your IP in there. Then log in with winbox and add the ppp and user manager packages.
If you’re doing NAT, you’ll have to set that up, I’ve never done it…
