rb750 configure hidemyass routing drop problem
Hi
i’ve configured my rb750 for connect to hidemyass service l2tp or pptp.
I’ve configured the routerboard with this online help http://www.wifitech.com.pk/pptp-client-or-vpn-client-config-in-mikrotik/
and working fine.
But have a big problem!!
if pptp/l2tp connection drop the routerboard route the traffic via normal router gateway this is very problem!!
if possibile to stop the routing if vpn client is dropped?
thnx for your response.
Use a firewall rule and block all this traffic from using the physical interface, so it can only go through the pptp interface.
