What can be this??? there is runnig a dude server…
another RB700 on network…100% CPU…flash!!! there is no dude, no proxy, no hotspot…
what is that???
Something is permanently writing NAND disk.
Check log and graphing settings.
HTH,
nothing in log…
first of, make sure you are running latest RouterOS and then try again.
With dude running on the router - check if you have set delayed write to conserve the nand.
Yes, in both 750s are ROS 5.4 … I will try 5.11.
Where is “delayed write” setting in dude?
We have the same problem on 6.9
same problem in ROS 5.26 on RB750. please help
