Good morning friends, are my first contacts with the mikrotik world and already gave to realize the range of possibilities that this equipment can offer, however I am not knowing how to configure my RB. I need a help to configure the equipment in the following scenario:
My RB receives the internet from the provider via PPOE with a FIXED IP;
It would also distribute the IP on the network via DHCP to the
I will have in this network 4 equipment ocm IP FIXO being one of them is another wirelles router with the function of chekin on facebook and worked only as an access point for visitors.
I have a Switch connected in this network where the network cables of the workstations arrive
I’ll need to perform a PPTP VPN setup for one of the directors accessing the internal network to access folders and documents inside one of my servers.
I tried some tips with videos on Youtube more unsuccessfully, I restarted my RB and it is with the default configuration, and I’m using Winbox v3.18 to access RB
“The Point-to-Point Tunneling Protocol (PPTP) is an obsolete method for implementing virtual private networks.”
Cannot recommend any solution for this due to the above.
Does the direction have a fixed WANIP address, in other words you could setup port forwarding and limit access to his/her WANIP
and rely on security protocols of your server login-password (but only if tls etc capable).
Otherwise vpn via other methods is probably best.
Another option is to set him/her up at home with a hex router and create an EOIP tunnel.
Hello Anav, thanks for the explanation, I believe that the option of port redirection is the best at this time, there will be no investment by the company on another router, in this case as I said I am a little lay still in mikritik, I would like to learn the configure my RB from scratch to offer DHCP, with an internet link on the WAN connected to a switch and a connection with the wirelles access function for the clients, but I could not get RB to distribute DHCP to anyone connected via Wirelles, even closing the PPTP tunnel the connected desktop did not see the machines on the network, I would like to understand why even PPTP being a discontinued security protoloco would like to do some tests in my residence in the future to understand better.
