RB750 hotspot setup problem
Hi friend,
Can help me I have RB750 when I setup hotspot problem with limit user:
Ex: I create 1 user: admin/admin
  • First user: Access have login page and with admin/admin
  • Second user: Access to website without login user/pass can access free…
Please give me advise…
What is the problem, I need to upgrade firmware or I need to configure some where.
Your after hotspot IP Bindings.
Sanwcl, thanks.
But am not need bypass.
I need yo block per user I sale hotspot card.
limit the uptime per user, so whenever the uptime limit is reached, the username and password you provided will no longer usable.
I mean, when the first user is login, the second and all user can access to wifi without ask user/pass.
It’s look like buy one user can use all PC.
regards,
Sounds liked you do not have the radius sever settings turned on for all users.
Go into the radius and check that it is active.
Cabletech,
Please find below setup:
I try many time, still can not fix the problem.
if have one user login the after user no need login can use directly.
thanks
I think you are distributing Wi-Fi from a DSL router. Distribute Wi-Fi from an AP your problem will be fixed.
Hi arjuneu,
  1. Am assign Ethernet-05 on Mikrotik RB750 for hotspot.
  2. And I connect my Wifi router:
  • Wan I get DHCP IP from Ethernet-05 on Mikrotik RB750
  • LAN I assign IP
  • DHCP I enable (all client get IP from My wifi)
can you help correct it?
regards,
Piseth
Hi, It’s working when I configure get DHCP from Mikrotik.
But when can i disable multiple login?
http://i1song.com/mikrotik/6.jpg
Using a wifi router is causing your problem. Switch to AP from router. I recommend UBNT NSM2 or Mikrotik SXT G-2HnD.
thanks, I will try, now it working fine.
