i just have the RouterBoard RB750, i need to show a login page each time a user try to connect to the lan to go to internet.
how have i to start ?
i have connect the rb750 to my modem router, and my pc to the rb750, i dont’ understand why it doesen’t show my the login page! …while if i connect my pc to the modemrouter ..and my rb750 to my modem router too… it show me the login page!? .. i don’t understand!..
could any one please help me ?
thank you normis,
i tried but it doesn’t work, ..i’m sure there’s something i make that’wrong.
I’m confuse about the entries i got insert when i click on “hotspot setup”
my adsl-modem-router is : 192.168.1.1
my RB750 is : 192.168.88.1
i connect :
at the 1° Lan-port of my RB750 → to the adsl-modem-router
at the 2° Lan-port of my RB750 → ..i connect a pc where i run WinBoxLoader to setup the RB750
at the 5° Lan-port of my RB750 → ther’s a pc where i need to display the loginpage to go to internet
how could i setup my RB750 ?
now, the pc at the 5° Lan-port receive the ip from the dhcp .. and get the IP : 192.168.88.224 and it go on internet too!
but i’m not able to display the login page befor it go on internet!
i connect :
at the 2° Lan-port (master) of my RB750 → ther’s a pc where i need to display the loginpage to go to internet.
at the 5° Lan-port of my RB750 → .i connect a pc where i run WinBoxLoader to setup the RB750
The port to run hotspot is the master, and now it works.
i ha ve to discover what is the difference between Lan-port 2° (master ) and the other (slave)
