[RB750] no access: IP: 0.0.0.0
I think I killed my RB750. The only question is, how did I do it?
Well, I basically resetted the RB750 because I forgot the admin password. It did not work first, so I repushed the reset button several time and broke the mini reset button. Well, there´s the other ROS reset jumper hole, which I used afterwards.
So, now it seems to boot. With Winbox I can see the MAC address but the IP is 0.0.0.0 and therefore I cannot connect.
So, how can I access the device? Can one of the LAN ports be used?
Michael
Click with your mouse on the MAC address instead IP and Winbox will connect just fine.
That worked. Thank you very much!
Did not work for me :frowning:
