I would like to downgrade a RB750 to V3.30.
Unfortunately, during the V3 to V4 upgrade a xxxx-yyy.key file was not generated.
I have checked other RB4XX systems, and they all have the xxx-yyy.key for V3 in the “files”.
Is there any way to downgrade the RB750 to V3.30 and get the V3 key back?
Thanks in advance,
By the way:
I dowgraded to V3.30 and apparently the RB750 is happy with the V4 key…
normis
3
your old key is in your mikrotik.com account, but don’t use it. v3 works fine with new keys (after v3.25)
hci
4
I noticed a .key file in many of my routers now. Is this file necessary or can it be deleted?
Chupaka
5
it’s just a backup of old-format keys. if all is working fine, just delete it. anyway, it should be in your mikrotik.com account
