I purchased a new RB750 router and tried to configure a dual WAN configuration without success.
Now I discovered I cannot even connect a single WAN whenever I use a static IP.
I think my RB750 has a defect and needs to be returned, unless I am overseeing something obvious.
Please help me figure this out as I am already spending way too many hours on this.
First of all, I reset the RB750 to factory settings with /system reset-configuration (type Y)
If I connect ISP1 on port1 (this ISP allows for DHCP), the RB750 receives a correct IP address and everything works as it should, my client PC’s have internet access and receive a correct IP from the router.
However I need to connect ISP2, so I disconnect ISP1 and connect ISP2 on the same port1.
This ISP2 supplied a static IP address and gateway address and I cannot get it to work. However if I connect this ISP2 directly to a laptop and I put in this IP address and gateway and DNS=8.8.8.8, the laptop has Internet and everything is normal.
So I resetted the RB750 again to factory settings which ether1 as a WAN port with DHCP (ether1-gateway) and ether 3-5 with a switch to ether2-master-local) LAN.
I removed the DHCP-client rule for port1 (ether1-gateway) and
I added the next 3 lines (ISP2-staticIP=184.71.227.62 & ISP2-gateway=184.71.227.61):
/ip address add address=184.71.227.62/30 network=184.71.227.60 interface=ether1-gateway
/ip route add dst-address=0.0.0.0/0 gateway=184.71.227.61 disabled=no
/ip dns set servers=8.8.8.8,8.8.4.4 allow-remote-requests=yes
I disconnected from ISP and PC and rebooted several times and rebooted the ISP2 modem, all without success.
ISP1 also has a static IP address, which is automatically assigned with DHCP. I tried removing DHCP-client rule with ISP1 and adding the 3 lines, but then with the gateway=206.75.200.0 and IP=206.75.200.154 and I got the same results. I doesn’t work.
With both (not working) connections I tried starting “New Terminal” and pinging a WAN ip-address that can be pinged and this results in getting timeouts only.
Did I forget something?
Kind regards,
Gary
