I have installed OpenWrt on a MikroTik Routerboard RB750UP (AR7240 CPU with AR9330 built in switch). I have included additional details below, but my question is:
How do I configure an untagged and tagged vlan on the same port?
I have successfully configured non-tagged vlans and tagged vlans independently, but not for the same port. The reason why I want to do this is because I have a Ubiquiti NanoStation loco M2 plugged into a port providing a wireless lan (which requires untagged frames), but I also want to configure a tagged vlan for managing the loco (i.e. accessing its management ip via tagged van).
Here are some further details:
Hardware
- MikroTik RouterBoard RB750UP
- Ubiquiti NanoStation loco M2
# swconfig dev eth0 help
switch0: eth0(AR7240/AR9330 built-in switch), ports: 5 (cpu @ 0), vlans: 16
<snip>
Here’s a diagram of (what I believe to be) the layout of the AR7240/AR9330 switch in the RB750UP:
Operating System
OpenWrt BARRIER BREAKER (Bleeding Edge, r36085), built with a custom configuration
# uname -a
Linux OpenWrt 3.8.3 #3 Wed Mar 27 04:09:04 PDT 2013 mips GNU/Linux
Network Diagram
As the image shows, the NanoStation loco is plugged into port 3 and has a management IP of 192.168.20.10/24 configured on a vlan with vid=3. It also acts as a wireless bridge/access point for the 192.168.100.0/24 network.
Accordingly, port 3 on the router has an untagged vlan configured for the 192.168.100.0/24 network and a tagged vlan for the 192.168.20.0/24 management network (with vid=3).
Network Configuration
Here’s what I’m trying to achieve with the below config:
- Tagged VLAN 3 (vid=3) on port 3 (virtual interface eth0.3)
- Untagged VLAN 4 on port 3 (virtual interface eth0.4)
- Default vlan pvid=4 on port 3 (to handle incoming untagged frames)
# cat /etc/config/network
<snip>
config interface 'loco'
option proto 'static'
option ifname 'eth0.3'
option ipaddr '192.168.20.1'
option netmask '255.255.255.0'
config interface 'locolan'
option ifname 'eth0.4'
option ipaddr '192.168.100.1'
<snip>
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option vid '1'
option ports '0t 2 4'
config switch_vlan
option vlan '2'
option vid '2'
option ports '0t 1'
config switch_vlan
option vlan '3'
option vid '3'
option ports '0t 3t'
config switch_vlan
option vlan '4'
option vid '4'
option ports '0t 3'
config switch_port
option port '3'
option pvid '4'
After rebooting the router, swconfig shows the following switch configuration. Note the missing ‘3t’ from VLAN 3.
# swconfig dev switch0 show
Global attributes:
enable_vlan: 1
Port 0:
pvid: 0
link: port:0 link:up speed:1000baseT full-duplex txflow rxflow
Port 1:
pvid: 2
link: port:1 link:up speed:100baseT full-duplex auto
Port 2:
pvid: 1
link: port:2 link:down
Port 3:
pvid: 4
link: port:3 link:up speed:100baseT full-duplex auto
Port 4:
pvid: 1
link: port:4 link:up speed:100baseT full-duplex auto
VLAN 0:
vid: 0
ports: 0t
VLAN 1:
vid: 1
ports: 0t 2 4
VLAN 2:
vid: 2
ports: 0t 1
VLAN 3:
vid: 3
ports: 0t <----- no tagged port 3!
VLAN 4:
vid: 4
ports: 0t 3
As a result, I cannot ping the loco’s management IP.
I’ve also tried manually configuring the vlan/port assignment and tags using ‘swconfig’, but in each permutation, it either leaves port 3 out of one of the vlans, or it forces port 3 to be tagged in both vlans.
Questions
- How do I configure an untagged and tagged vlan on the same port?
- Are there any known bugs/issues with swconfig or the AR7240/AR9330 OpenWrt switch driver that could be causing this? (None came up in my searches.)
