RB750 out of disk space
My RB750G (v4.16) shows that I have 0% disk space available (61.4MB out of 61.4MB used) even though there is no file in the user space (the output of the “/file print” command does not show any files).
How can I recover the disk space?
Thank you in advance.
Chris
I forgot to mention that “Resources” was showing that I have 28MB of disk space available however the “Files” showed that all the disk space has been used and I could not upload anything to the RB’s HDD. I have resolved the problem by resetting to factory, uninstalling Dude and IPv6 and reloading the configuration.
Now the free HDD space reported by “Resources” matches with what the “Files” screen is reporting (32MB free).
Any packages you no longer need, such as User Manager or TheDude?
Failing that, it’s a /export of all the settings via a console connection, then a full reset/wipe, then a re-import of those previously saved settings.
