RB750 problems setting it up for e-mail
Hi all - I ve installed an RB750 router between the Internet and the mailserver and I wish to set it up for e-mail access and webmail ie: allow access to these ports:
http 80 for mail server
smtp 25 for spam filter
pop 3 for mail server
dns 53
Attached is a topology with the IPs in use and also the config attached.
For some reason I cannot get the WAN interface to transmit any packets…what am I missing?? it’s TX Status is idle whilst the TX status is OK…!!
myconfig.rsc (12.6 KB)
Check “/ip route”. I see no default gateway.
add gateway=xx.xx.43.217 dst-address=0.0.0.0/0
If the xx.xx.43.17 is not the gateway for your public network, then change it.
