RB750 series hotspot problem
Dear Gurus;
I have a 750 series wireless and I turned on hot spot and now I cant logon using the hotspot lgon and now winbox doesnt let me in so I cant fix the wireless.
I never set up any user and the only user I use in winbox is admin with my password but now winbox doesnt work anymore.
How do I fix my wireless to get back in if my admin password and and user doesnt work on hotspot or winbox???
I would get the exact model but I cant logon and I cant look at it physically at this moment
Help :frowning:
If you used “/ip hotspot setup” to set up the hotspot, at the end it asks for a username and password for a “default user”. Did you enter that? If so, use it to login to the hotspot with a web browser, then you can connect with Winbox or ssh.
Do you have another interface that is not on the hotspot interface and has an ip assigned? You should be able to use that interface/ip to connect.
Otherwise, a router reset may be the only option.
