As above, RB750 v5.4 cannot use export compact
Get error ‘expected end of command’ suggesting it doesn’t like me adding compact to the end of the export command.
Any ideas?
The command didn’t appear until around v5.12 . It will be there if you update RouterOS.
Upgrade to 5.12 or later might help
What’s new in 5.12 (2012-Jan-19 14:31):
*) console - added support for compact export;
…sorry ignore me…for some reason my brain read 5.4 as a higher revision than 5.12 ![]()
