RB750 VLAN and Internet
Good Day
Is there a way to have on vlan ether3,ether4,ether5 to have internet. At the moment on my rb750 i use ether1 as Wan and ether2 as my hotspot(usermanager).
What i like to know is if i vlan ether3 - ether5 that i can have different ip ranges as well as connect them to the existing hotspot(usermanager)
Thank You
Louis
Yes you can. Add the vlan interface to the phyiscal. If you have the same vlan id on two different ports, you can create a bridge to tie them together if needed.
