Rb750G act as a layer 2 firewall like a netscreen or ASA?
Can a RB750G switch act as a layer 2 firewall where I can just drop into a network transparently?
Yes. You can either turn on IP firewall filters for bridged traffic (under “/interface bridge”), or you can use bridge filters directly. On a 750G you will have to turn off the switch chip for that to work - that traffic isn’t processed by the CPU. You’ll have to software bridge things (which doesn’t perform as well).
For clarification. Does the switch chip work only for “IP firewall filters for bridged traffic (under “/interface bridge”)” and not “bridge filters directly” or it is not utilized in either method?
It isn’t utilized with either method. There is very rudimentary filtering on the switch chip, but nothing that approaches a firewall (and the rule set size is very limited). If it’s processed by the switch chip, it isn’t seen by the CPU. Both IP and bridge rules run in CPU.
Can you tell me what I have wrong here?
I want to allow only IPsec-esp, ssh, isakmp 500 and 4500. But I am unable to BLOCK ssh as a test.
[admin@MikroTik] > interface print
NAME TYPE MTU L2MTU
0 R ether1-gateway ether 1500 1526
1 R ether2-local-master ether 1500 1524
2 ether3-local-slave ether 1500 1524
3 ether4-local-slave ether 1500 1524
4 R ether5-local-slave ether 1500 1524
5 R bridge1 bridge 1500 1524
[admin@MikroTik] > interface bridge print
0 R name=“bridge1” mtu=1500 l2mtu=1524 arp=enabled mac-address=00:0C:42:57:11:78 protocol-mode=none priority=0x8000
auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
[admin@MikroTik] > interface bridge filter print
0 chain=forward out-interface=ether2-local-master action=accept in-interface=ether1-gateway mac-protocol=ip
src-address=0.0.0.0/0 dst-address=70.42.209.128/27 ip-protocol=ipsec-esp
1 chain=forward out-interface=ether2-local-master action=accept in-interface=ether1-gateway mac-protocol=ip
src-address=0.0.0.0/0 dst-address=70.42.209.128/27 src-port=500 dst-port=500 ip-protocol=udp
2 chain=forward out-interface=ether2-local-master action=accept in-interface=ether1-gateway mac-protocol=ip
src-address=0.0.0.0/0 dst-address=70.42.209.128/27 dst-port=4500 ip-protocol=udp
3 X chain=forward out-interface=ether2-local-master action=accept in-interface=ether1-gateway mac-protocol=ip
src-address=0.0.0.0/0 dst-address=70.42.209.128/27 dst-port=22 ip-protocol=tcp
[admin@MikroTik] >
Can someone tell me what I did wrong with these filter rules?
Did you put a general drop rule at bottom of your list?
