RB750G firmware upgrade problem
I try upgrade firmware via windows in WinBox and via Terminal but unsuccessfully i have always old version:
system routerboard print
routerboard: yes
model: 750G
serial-number: 228E01AEDC76
current-firmware: 2.23
upgrade-firmware: 2.36
I try method from this forum:
/system routerboard settings set force-backup-booter=no;
/system routerboard upgrade
Do you really want to upgrade firmware? [y/n]
y
firmware upgraded successfully, please reboot for changes to take effect!
system reboot
Reboot, yes? [y/N]:
y
But after reboot i have always old firmware 2.23.
Please help me!
Check the following option,
and after this command try to upgrade firmware one more time.
I try:
But without success. After reboot i have always:
You might try going step wise. I just did this last night going from 5.6 with boot loader version 2.29 to 5.7 with version 2.36 without any problems. The big difference seems to that I’d already upgraded from 5.5 to 5.6. No idea why it might make a difference, but it’s certainly worth a shot.
I just uploaded the packages (routeros-mipsbe-5.7.npk combined core, and ntp-5.7-mipsbe.npk optional), rebooted, then after that settled used the webconfig UI to update the firmware and rebooted again when it said to.
OK, firmware was successfully upgraded.
First I downgraded OS to 4.17 there was possible upgrade firmware to 2.29 and after upgrade OS to 5.7, firmware was successfully upgraded to 2.36 .
Thank you for your help!
I’ve tried this too, still stuck on 2.23 :confused:
Le Chat
What packages did you install for 5.7?
did you also do:
Yes, tried that. Even rolled back to 4.17 and tried an upgrade from there..
Le Chat
What I’m wondering here is if you might get different results using the combined .npk package versus the separate ones…
should not be the case, as combine package is made out of separate ones, just easier way to upgrade router with one package.
I’ve only installed
ntp-5.7-mipsbe.npk
is there any logging which can be enabled to show a routerboot upgrade and/or failure ???
this is where the 750s with no serial can be a real pain.
any update on how to fix stuck firmware upgrades ?
use the button to load backup bootloader.
Any chance you could actual explain it so that we can understand it ?
Which button ?
One in winbox ? The reset button ?
Did you read the thread, we have tried all kinds of things as suggested and its still stuck, and won’t upgrade
NIck.
which thread? this is your first post in this thread
The whole thread LeChat is one of our customers.
I did not know that.
  1. Type “/system routerboard upgrade” and then make a supout.rif file without rebooting. Send the file to us
  2. Organize remote access to this device, so we can connect and see what’s going on (email support for this, and also attach that file)
