Hi there.
I have a mikrotik rb750g which im using to split traffic between 3 adsl line.
I have also setup layer 7 and im running it on ether3, ether 4 and ether5 which is the Ethernet ports that the adsl routers are connected.
The cpu load is about ±50%.
Sometimes when I enable some of the rules in mangle for example: When I enable rule which allows my computer to route though different gateway then the cpu load will go 100%.
And if I try to winbox into router using the ip address then I will get error “connection refused”. And if I can log in using mac address on mikrotik then I wil get disconnected after 3 seconds in winbox.
Logs will show that router rebooted because of kernel failure.
Then I have to telnet into router using putty and reboot the router.
After I have done that then the router will work fine again.
It only happens sometimes, maybe the router is getting confused that I am disabling/enabled the rules too much.
The ROS that is running on router is 5.14
