We noticed RB750G is EOL and replaced by the 750GL which contains double memory.
We were full of joy untill we noticed the CPU was clocked down (and probably software locked) to 400MHz. Why is that?
I don’t understand the approach of doubling the ram and at the same time downgrade the cpu frequency while 750G and 750GL contain exactly the same cpu.
Ok, that clears up the fact that it isn’t the same cpu, I didn’t really investigate, just used “/system routerboard print” which showed the same cpu model.
But still, it would have been a much more nice device with a 680MHz cpu and I don’t understand why a lower clocked model was chosen for this.
Yes, but it also lowers performance and I don’t think the price difference between those two cpu’s is that big.
I would be happy to pay a few $$ more if the device was equipped with a faster cpu like the one in RB750G
I believe the RB750GL has much larger MTU capability that the RB750G.
Even though the clock speed might be less, I’ll bet the transfer speed efficiency will make up for it. Just a guess though.
I bought over a hundred 750g and only few 750 the last year, the cpu upgradable to 800mhz is not comparable to the new 750gl sorry but this product is not necessary, for me is only a 100/1000 switch, the cheapest 750 will be for now my choice.
Indeed, like I said, the RB750GL would have been a great product improvement if the cpu was left unchanged. @tjc: This depends heavily on what you do with it. If you have lots of shaper queues you will notice the difference!
True enough, power users can almost always find ways to use more cycles if they’re available.
On the other hand, what % of the RB750G’s out there never use more than 5-10% of the available CPU? My SWAG would be at least 75% and probably more like 90+%. Since they still have other options for those who need the extra speed it seems like a smart move.
