i have a rb750g on a tower 80 meters of ground now its connected to 4 ubnt sectors with their radio’s all lans are active but i can t login to the router it brings up when i try loging in by mac address port 20561 and when i try with ip 0.0.0. it says could not fetch port 80 etc is their anyway to login without bringing it down and connecting it to the lan port manualy and loging in via mac ?
If you are not able to login by
- SSH Telnet;
- IP Winbox;
- MAC Winbox
- MAC-Telnet from Neighbors;
Then you have to prepare replacement and climb up to the tower and exchange the RouterBOARD, then make inspection where was the problem.
