I ordered +/- 10 RB750GL’s and am busy configuring them now.
I already got 3 of them not booting (brandnew out the box)! I tried to reset to defaults with the hardware button, but no joy. (yes, i use the right procedure) The led’s of ether 1 & 2 (where my utp is connected) are constantly blinking.
I have no access to the devices in any way. What can I do? I need them asap in the field!
Hi Normis, thx for coming back to me.
Jumper on the bottom? I don’t see a jumper?
To reset, I hold the reset button with a pen, then plug the power and when the ACT starts flashing I release the reset button and the device resets to defaults normally.
kind regards
B
PS WIth one of the devices I noticed leaving it on the power for +15min gave me access to it.
After upgrading to ROS5.6 the device seems to act normal. Did you have issues like this before with ROS5.2 on RB750GL
Ah ok, good to know, thx.
FYI, I was able to recover them all by letting them connected to power and ethernet for 15 to 20 minutes.
After that time the router became accessible and I was able to upgrade FW to ROS5.6. I didn’t have any issues anymore after that.
I’ve never seen such behaviour on any other MT device I had in my hands in the past. Anyway, I’m happy it’s solved RMA is always a PITA (I don’t mean the RMA service of MT, but the hassle that comes with it)
