Hello guys,
I have RB750GL and i have a problem with it and can’t solve it and no one know how to fix it .
the problem is he work and his led is flashing and he responding to reset and the led is flashing as should be but i can’t connect to it and the computer doesn’t get a valid ip from his DHCP . i try to install new fresh Software via netinstall-5.17 and connect it to Port No 5 once and Port No 1 Once more but he also don’t recognizing it and not show in the program .
unfortunately RB750Gl Don’t have Serial Port and i don’t know what i can do to connect to him and reuse it in my network .
when i checked the RB Hardware I did not find anything suspicious raises doubts .
Plz give me your advice to save my RB .
use netinstall 6.12 and routeros 6.12 (use only upgrade package routeros-mipsbe-6.12)
but when you use netinstall do not set “keep old configuration”
thanks For help , i’ll try and give you feedback .
nothing new, the same act unfortunately .
Is there a possibility that the memory chip has been damaged or hit by something wrong??
up .
Plz , any body help me fix my RB ,i still waiting any experience one has see this problem before
Have you tried connecting to the routerboard using the “MAC” method? In that case it’s IP and such don’t matter.
Please see: http://wiki.mikrotik.com/wiki/Initial_MAC_Winbox_Connection
I think I might have the same problem, also with an RB750GL.,
After booting the unit is responsive for a couple of seconds (30-60) and let me connect, but afterwards gets disconnected and is unreachable until next reboot.
I have installed RouterOS 6.12 via netinstall several times, the last time only put the system package on but nothing changes.
After install and reboot I have managed to setup an IP address on an ether port but after 1 minute, I can not connect anymore to the device.
Also found that after some time, when a connected ether interface gets disconnected, the LED stays on and also blinks once in a while.
Another thing I noticed is that when the unit is unresponsive it looks like it is acting as a plain L2 device.
With no config in the malfunctioning routerboard I happen to get an IP address from any DHCP server connected to the broken routerboard, while my PC is connected to a different port of the broken routerboard. But since no config is applied, all ports should be on their own, not passing any broadcast traffic or what so ever.
I have managed to pull a supout.rif file from the device short after boot and sended it to the MikroTik support.
I hope they can find any issues with the unit.
