Hi All,
Our ISP connection require VLAN and Priority. I understand that RB750GL support switch rule where we can modify the header to add priority.
Port 4 is Master port and Port 5 is Slave. I have created a VLAN 100 and 200 under Ether4 interface. When i try to create switch rule involving “switch1 cpu” port to add priority to all incoming packets tagged with VLAN 100 and redirect to Ether5, inbox prompt error "Couldn’t add new switch rule - vlan-id, clan-priority, new vlan-id not supported for this switch (6).
Does it mean it doesn’t support condition on the rule which originating from “switch1 cpu” ?
