RB750GL Upgrade to 6.7?
Just getting started with my first managed switch, sorry for the beginner questions.
I’ve upgraded my router via the packages option, and upgraded the Routerboard firmware, however both only upgrade to 5.26 and 3.09, respectively.
Can this model be upgraded to 6.7? If so, what’s the appropriate method to do so?
Thanks,
Tim
That can
You can just upgrade to RouterOS 6.x
Just drag an drop the desired package files onto the RouterBoard via Winbox, files
Reboot the system and done.
