RB750GL USB
I know the RB750GL product page doesn’t talk about USB, and the only (two) search hits are in the negative, but could anyone explain why I see this?
[admin@RB750GL] > system resource usb print
 # DEVICE VENDOR                             NAME                           SPEED
 0 1:1                                       RB400 EHCI                     480 Mbps
I haven’t opened my case up to look, but is there a secret header on the board I can solder a USB connector to?
I have notice that, too. But I think that USB port is not implemented, maybe you can solder one if You have skill, on appropriate place.
the processor has the port incorporated, but MK doesnt connected to it..
Ex: integrated usb in the motherboard but u didnt connected frontal usb port…
something like it,
There have been a couple questions like this recently.
For example someone noticed that the current RB750 has a place for it on the PCB but it’s unpopulated: http://forum.mikrotik.com/t/its-possible-add-an-usb-port-to-rb750/54344/1
The RB750GL also has the same unpopulated USB pads on it’s PCB, see the picture here: http://routerboard.com/pdf/355/rb750gl-ug.pdf
It looks like the hardware design has been done and all Mikrotik would have to do is populate the connector, usb driver chip, and miscellaneous components.
i will kill my self only 2 day ago i buy this router rb750gl and got it to use cash and with out usb how that will work
