RB750GL
Respected Fellows.
i am using router board 750GL. My junion disabled all ports and now its not accessible even through MAC. I have to reset it.
My query is that!
i have backup files saved on router. unfortunately haven’t export the backup file. if i reset the router? will it remove backup files also ?
kindly guide me the solution, if accessing the router board possible with some other way / or to save my backup file. thanks
The files should stay. At least for me they always stayed. So far. Anyway you have no option.
If you not use netinstall staying the files on the routerboard
