RB750GR limiting download a 400mp
Good morning,
I’m new here on the forum, and I would really like some help because I have a problem using my Mikrotik, the download of it does not exceed 400mp and my plan is 800mp, and using the operator’s router it takes 800mp easily , my mikrotik reaches a maximum of 400mp of download and 800 of upload.
Is this a limit for this model or do I need to configure something for it to exceed this limit?
Please read this article carefully, it may be useful to you.
https://wiki.mikrotik.com/wiki/Manual:IP/Fasttrack
Regards,
I am happy to know that it was just a configuration, I was already advertising my RB for sale, I thought it could be a limitation of the RB, and I had to buy a superior one. Thank you very much!
This doubt I could only solve here, I couldn’t find it anywhere on the internet, I hope my doubt helps someone else.
If you are using Vers6 firmware you may be able to reach 800, some could I think I was maxed between 700-800.
With Ver7 firmware I think 400 is probably the new max. Certainly if recommending a router within a budget,
I would look at the hapax3 for throughput and modern components arm64, RAM etc… this will yield success for a 1gig connection.
Good morning,
I came to share how I solved my problem in case anyone else has it in the future.
Your I used the command lines and left these rules as first in the order of the rules in the firewall
/ip firewall filter add chain=forward action=fasttrack-connection connection-state=established,related
/ip firewall filter add chain=forward action=accept connection-state=established,related
Now I’m getting all my 800mb of internet both downloading and uploading :slight_smile:
