Comparing the specs it appears r3 no longer has wifi?
Am I missing something here?
https://mikrotik.com/product/RB750Gr3
https://mikrotik.com/product/RB750r2
Neither list wifi under specs but im sure i used the r2 in the past and it has wifi?..
Some third party sites show them as having wifi listed under specs?..yet not on the mikrotik site?
Wireless communication standard 802.11n
Wireless communication standard 802.11bgn
Could it be that you used the following? They look similar to RB750.
https://mikrotik.com/product/RB951Ui-2nD
https://mikrotik.com/product/RB952Ui-5ac2nD
Thanks!
Im thinking this must very well be the case.
And we just so happened to have a bricked 750r2 kicking around from some other job that was assumed to have been a spare backing up the wrong assumption :S
Blah, thanks a bunch!
