rb750gr3 compatible with Router OS v7
Hi
Is the rb750gr3 compatible with Router OS v7? I haven’t found a way to upgrade to this new version yet.
Here is the spoon, open wide!!!
Hex ?
Last time I checked mine is running ROS7 since beta 1. Never went back to ROS6.
If you upgrade to latest 6.x (6.49.2 at the moment), you will see 7.1.1 under testing and upgrade train.
I was just replying to your question.
Yes, it compatible, and showed how to upgrade.
Now your reply.
RouterOS 7 is not an option
Why did you then ask this in first place?
