Hello everyone,
I’m working on configuring my RB750Gr3 and my intended setup is as follows:
Eth1: ISP
Eth2: LAN
Eth3: Access Point / Mesh
Eth4: LAN with VLAN
Eth5: Spare
I’ve already set up the VLAN for Eth4, which includes VLANs 20 and 30. I’ve watched tutorials on YouTube and read various documents, but I’m unsure what went wrong as I’m unable to obtain an IP address from my VLAN. I’ve tried connecting my laptop to Eth4 and even set a static IP, but it still isn’t working. I’m still a beginner at this.
Thank you in advance!
Current Config:
# oct/26/2024 14:20:56 by RouterOS 6.49.16
# software id = 00000
# model = RB750Gr3
# serial number = 0000000
add name=bridge1-vlan vlan-filtering=yes
add name=ether4-bridge vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1-ISP
set [ find default-name=ether2 ] name=ether2-RPI
set [ find default-name=ether3 ] name=ether3-AP1
/interface vlan
add interface=ether4 name=vlan-20 vlan-id=20
add interface=ether4 name=vlan-30 vlan-id=30
add name=dhcp_pool0 ranges=10.0.10.2-10.0.10.254
add name=dhcp_pool1 ranges=10.10.20.2-10.10.20.254
add name=dhcp_pool16 ranges=10.1.20.2-10.1.20.254
add name=dhcp_pool17 ranges=10.1.30.2-10.1.30.254
add address-pool=dhcp_pool0 disabled=no interface=bridge1-vlan name=dhcp1
add address-pool=dhcp_pool16 disabled=no interface=vlan-20 name=dhcp2 relay=\
10.0.30.1
add address-pool=dhcp_pool17 disabled=no interface=vlan-30 name=dhcp3 relay=\
10.0.30.1
add bridge=bridge1-vlan interface=ether2-RPI
add bridge=bridge1-vlan interface=ether3-AP1 pvid=4
add bridge=bridge1-vlan interface=ether4 pvid=20
/interface bridge vlan
add bridge=bridge1-vlan tagged=ether2-RPI untagged=ether3-AP1 vlan-ids=2
add bridge=ether4-bridge tagged=ether4 untagged=ether2-RPI,ether3-AP1 \
vlan-ids=20,30
add bridge=bridge1-vlan tagged=ether2-RPI,ether3-AP1 vlan-ids=20
add bridge=bridge1-vlan tagged=ether4 vlan-ids=30
add address=10.0.10.1/24 interface=bridge1-vlan network=10.0.10.0
add address=10.1.20.1/24 interface=vlan-20 network=10.1.20.0
add address=10.1.30.1/24 interface=vlan-30 network=10.1.30.0
/ip dhcp-client
add disabled=no interface=ether1-ISP
add address=10.0.10.0/24 gateway=10.0.10.1
add address=10.0.20.0/24 gateway=10.0.20.1
add address=10.0.30.0/24 gateway=10.0.30.1
add address=10.1.20.0/24 gateway=10.1.20.1
add address=10.1.30.0/24 gateway=10.1.30.1
add address=10.20.20.0/24 gateway=10.20.20.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
add action=masquerade chain=srcnat out-interface=ether1-ISP
/system clock
set time-zone-name=Asia/Manila
Hello everyone,
Eth1: ISP
Eth2: LAN
Eth4: LAN with VLAN
Eth5: Spare
Current Config:
# model = RB750Gr3
/interface vlan
10.0.30.1
10.0.30.1
vlan-ids=20,30
/ip dhcp-client
/system clock
I have fixed it, Thank you!
I cant closed the thread.
