Hello! I’ve tried USB flash drive on older boards. Got 2-3MB/sec write/read speed with cpu LOAD 100%.
Can anyone share info regarding microSD or USB write/read speed on newer boards like RB750Gr3?
Thanks.
Thanks.
same router,I use the USB-HDD to test . 15-20MB/S and cpu also high.
Thanks. Actually that’s very nice. I have 100Mbit network so rate would be limited to 10MB/sec and I wont overload the router.
I didnt expect such high rate from router. Ordered that board… will test it out on weekend, will share my results.
Okey so I tested so far few USB Flash Drives, doesnt matter ftp/samba or ext3/fat32 - Write Speed 2-3MB/sec
It takes only 10% CPU load, but speed the way to slow… Same flash drives connected to PC are writable @ 10-12MB/second.
Using micro SD card is much better. I’m getting 6.5MB/second write speed at 16GB class 10 card. It takes about 20% CPU load.
I dont have USB hard drive to test at the moment, will post info later.
