I recently upgraded to a gigabit subscription and got a new modem sent by my ISP. My modem is operating in bridge mode. When I plugin a device in the bridge port I can see that I’m getting gigabit speed internet connection.
My Mikrotik RB750Gr3 is not getting anywhere near gigabit speed. Whenever I run a speedtest on my wired devices I get downloads speeds fluctuating between max 600 Mbps, 400 and even 100 Mbps.It constantly changes and I can not tell what is causing this. I never had these problems with my previous subscription (different modem) and always had the 600Mbps download speeds.
Today I did a reset and started from default configuration without any success. I made sure fast track is enabled and is the 1st rule on the firewall list.
What might be the cause and how to solve this?
My config:
# sep/23/2022 21:14:14 by RouterOS 7.5
# software id = QMGA-7TGX
# model = RB750Gr3
# serial number =
add admin-mac=48:8F:5A:16:52:65 auto-mac=no comment=defconf name=local
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=listBridge
/ip hotspot profile
add name=dhcp ranges=192.168.200.100-192.168.200.200
add address-pool=dhcp interface=local name=defconf
/port
set 0 name=serial0
add bridge=local comment=defconf interface=ether3
add comment=defconf interface=local list=LAN
add interface=local list=listBridge
add address=192.168.255.254/16 comment=defconf interface=local network=192.168.0.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.2.248 client-id=ff:e4:82:d0:7e:0:2:0:0:ab:11:e0:8f:2c:c4:fb:92:17:38 mac-address=\
42:5F:F7:4B:E6:7F server=defconf
add address=192.168.0.0/16 comment=defconf dns-server=1.1.1.1 gateway=192.168.255.254 netmask=16
set allow-remote-requests=yes servers=1.1.1.1
/ip dns static
add address=192.168.255.254 comment=defconf name=router.lan
add action=fasttrack-connection chain=forward connection-state=established,related hw-offload=yes
add action=accept chain=forward connection-state=established,related
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp \
src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Amsterdam
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
set allowed-interface-list=listBridge
/tool mac-server mac-winbox
