My router rebooted 10 ~ 20 minutes without reason. Things that I notice are only those:
feb/03/2017 09:09:48 system,error,critical router was rebooted without proper shu
tdown
feb/03/2017 09:17:37 system,error,critical router was rebooted without proper shu
tdown
feb/03/2017 09:17:45 ppp,error,critical pptp-out1: Encryption got out of sync - d
isabling
feb/03/2017 09:28:59 system,error,critical router was rebooted without proper shu
tdown
feb/03/2017 09:47:48 system,error,critical router was rebooted without proper shu
tdown
[admin@Vazov50] > export compact
/system routerboard settings
# Warning: memory not running at default frequency
set memory-frequency=1200DDR
I changed the power adapter.
I checked the voltage in electrical power.
But he reboot ?
Try to make a supout.rif file, or check if there is an autosupout.rif file in the Files folder. Send those files to support and we can check what is going on there.
I had this problem once. We had a faulty hardware due to bad POE adapter, have you checked it? Check temps, voltage, etc. And of course: supout.rif to Mikrotik’s staff.
I was having the exact same issue with the same hardware.
The RB750Gr3 was working fine for 13days and then started randomly rebooting.
Interestingly enough I had a second RB750Gr3 with virtually the same config with the only difference that the primary internet uplink was a PPPoE Client on the RB which rebooted randomly.
I didn’t solve the issue itself but made my desired config work with a workaround.
