After entering a configuration script I get this error message so I immediately interrupted the power from the router.
This is the script.
set [ find default-name=ether2 ] master-port=ether1 name=\
ether2-mirror-input
set [ find default-name=ether3 ] master-port=ether1
set [ find default-name=ether4 ] master-port=ether1
set [ find default-name=ether5 ] master-port=ether1 name=\
ether5-mirror-output
/interface ethernet switch
set 0 mirror-source=ether2-mirror-input mirror-target=\
/ip hotspot profile
/system routerboard settings
# Warning: memory not running at default frequency
set memory-frequency=1200DDR
The configuration script comes from the same router board.
RouterOs = 6.39.3
Firmware = 3.41
What is going on
