RB750r3 hEX - no file upload possibility
I have installed the Dude at RB750r3 hEX on microSD card.
Why there is no posiibility to upload any file under “Files” in Dude? ROS and Dude Version 6.38. I have tested under 6.39rc7 - the same. There in only file remove “-” button, but NO “+” button to add any file. Why?
Have you try drag and drop?
Of course I have tried - there is no possibility :frowning:
https://s24.postimg.org/w5v310nmd/Dude_Files.jpg
https://s28.postimg.org/fp7eq0pml/Dude_Packages.jpg
I had also unexpected behavior on mu Gr3 and I think remount the disk and restart helped then.
http://forum.mikrotik.com/t/the-dude-v6-37-current-release/101858/41
You can’t add files via the dude anymore - you need to use winbox.
