I’ve got an RB600 with two R52H cards that I need to be able to remotely power cycle.
Can the RB750UP handle an RB600 with two cards? It is around a 200ft ethernet run.
The RB600 is an 802.3af (48 volt) PoE device. The RB750UP is a 24V passive PoE device… You cannot power a RB600 with a RB750UP.
Don’t you have access to the CLI/winbox of the RB600?
rb600 - input poe voltage 36-56V
rb750UP have only 24V POE out
Hi!
I might work, but your cable is long and you have 2 hightpower cards total of 11W ≈ 0,5A on 24V
The powerjack accepts accepts 10-56V
If you use an POE-extractor and plug into the powerjack
https://www.wintherwireless.se/poekit-v2-1xinjector--1xextractor-w-dcconnector-for-ipcam-p-807-c-224.aspx
I have done this with success, but shorter cable
RGDS
Jörgen
rb600 = 9W
totaly with cards 13-14,2W it is on 24V = 0,59A
RB750up have 1A per port. It can mayby works
Problem can be lengs of cable.
upgrade firmware on rb750up to version 2.0
http://wiki.mikrotik.com/wiki/Manual:PoE-Out
Good luck ![]()
Thanks guys.
Yes, the RB600 can take 10-56V, currently running through the jack on 24v since lightning damaged POE port. Still powers on throughy it, but no data.
I was hoping to read that someone else had already done this. Looks like my replacement AP will be here soon enough.
