RB750UP PoE randomly turning on/off
Hi there.. I hope you can help me :slight_smile:
I’m experiencing a quite strange problem with my RB750UP. The PoE Output keeps randomly turning on/off (no matter if a device is connected or not) - I tried it with every Port on forced on and automatic mode. Could it be a hardware problem, because it works just fine sometimes..?
My current Firmware is 6.7 and all Packages are enabled..
Thanks in advance,
Flocom - Austria
I have some750 UP, but have never seen your problem. Do you yse original power? If so, it seems like a HW problem (might be a poe client having a strange problem)
I suggest to upgrade to latest RouterOS v6.8rc version and check whether it works ok. If not, then we need to know an output from
    /interface ethernet poe monitor [find]
It will show a reason why port is turned off in forced-on mode.
